Footrests keep legs elevated for improved posture and circulation while you work at a desk and help reduce pressure on the lower back. They are easily adjustable for extra comfort while there is a range of specifications available to suit individual requirements.
- Kensington SoleMate Ergonomic Footrest - foot-rest
- Product Type
- Foot-rest
- 45 cm x 35 cm
- 2.7 kg
- Non-slip feet, adjustable angle, 20° tilt
- 2-year warranty
- Product Type
- Foot-rest
- 45 cm
- 35 cm
- 2.7 kg
- Limited warranty: - 2 years
