Kensington Kensington Pro Fit® Bluetooth® Mobile Mouse - Black
Quicklinx: C1G7WS00 Mfr#: K72451WW
When you need a compact, mobile mouse that offers Bluetooth wireless performance and comfort, the Kensington Pro Fit Bluetooth Mouse has everything you need to be productive. The Bluetooth connection allows you to save a USB port on your device for other accessories, which is extremely convenient on modern ultra-thin devices that have limited port space. The high definition 1000 DPI laser sensor lets you scroll around your screen with precision control. The two-button, scroll wheel design is highly intuitive and works equally well for both right-handed and left-handed users. And best of all, with simple and easy Pair & Play installation, youll be up and ready in no time.
Kensington Pro Fit Mobile - mouse - Bluetooth 3.0 - black
Mouse
Wireless - Bluetooth 3.0
Orientation
Right and left-handed
5.8 cm x 9.64 cm x 3.3 cm
80 g
Movement Detection Technology
Laser
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, on/off power switch, automatic power off
AA type
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.9 - 10.11, Google Chrome OS 44
3-year warranty
Mouse
Orientation
5.8 cm
9.64 cm
3.3 cm
80 g
Input Device
Wireless
Bluetooth 3.0
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
3
Movement Resolution
1000 dpi
AA type
Limited warranty - 3 years
