Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter Expert with Green Laser Pointer, Cursor Control & 4GB Memory. The presenter stores your PowerPoint or Keynote files on the 4GB Micro SD card that fits into the wireless USB receiver. With a simple flick of a switch, you toggle between presentation and cursor control modes. Make your point with a green laser thats 10 times brighter than standard red lasers, ideal for bigger rooms and LED/LCD screens. The highly reliable 2.4GHz receiver resists device interference and gives you control from up to 150 feet away.
- Kensington Presenter Expert Green Laser Presenter with Cursor Control and Memory presentation remote control - black
- Presentation remote control
- Enclosure Colour
- Black
- 135 mm x 75 mm x 205 mm
- 202 g
- Localisation
- Europe
- Connectivity Technology
- Radio
- Max Operating Distance
- 50 m
- Battery
- Pointing device battery
- 3-year warranty
- 135 mm
- 75 mm
- 205 mm
- 202 g
- Enclosure Colour
- Black
- Localisation
- Europe
- Radio
- 50 m
- Low battery alert, built-in laser pointer, back-lit buttons, built-in 2 GB flash memory, power on/off
- Operating System
- Apple Mac OS, MS Windows 7, Windows 8
- Included Accessories
- Carrying pouch
- Battery
- 3-year warranty
