Featuring the latest in wireless technology, the PresentAir Pro Bluetooth 4.0 LE Presenter has everything you need to present with confidence and so much more. With USB ports at a premium on todays ultra-thin devices, the PresentAir Pro uses Bluetooth 4.0 LE technology to pair with your device. The PresentAir Pro buttons offer three modes Presenter, Media and Custom so you can select the button functions that work best for what youre doing. Download the free PresenterWorks app and discover all the options the Custom mode has to offer. The sleek design fits right in your pocket or you can place it into a pen/stylus holder. The presenter also works as a touch-activated stylus, and the red laser can call attention to any part of your presentation. The included carrying case provides convenient storage that protects the PresentAir Pro from scratches.
The latest in wireless innovation, this low-energy pairing between your device and presenter frees up a valuable USB port and offers a range of up to 30 feet so you can move freely during a presentation. -
Ultra-slim design
The presenter's thin profile makes it extremely light and easy to hold, plus it can fit into a shirt pocket or the pen/stylus holder found in many business folios or briefcases. -
Red laser pointer
Make your point at the touch of a button with a bright red laser that can highlight any part of your presentation with complete effectiveness. -
Touch-activated stylus
Compatible with all major tablets and smartphones, holding the metal enclosure turns the presenter into a fully functional stylus to navigate your way around the touchscreen on your device.
- Kensington PresentAir Pro Bluetooth 4.0 LE Presenter presentation remote control - black
- Presentation remote control
- Enclosure Colour
- Black
- 13.931 cm x 1.25 cm x 1.25 cm
- 18.5 g
- Wireless Technology
- Bluetooth
- Max Operating Distance
- 10 m
- Battery
- AAAA type
- 1-year warranty
- 13.931 cm
- 1.25 cm
- 1.25 cm
- 18.5 g
- Enclosure Colour
- Black
- Bluetooth
- 10 m
- Built-in laser pointer, built-in stylus, Bluetooth 4.0 LE, three modes, PresenterWorks
- Operating System
- Windows 8.1, iOS 8.0, Android 4.4
- Included Accessories
- Carrying case
- Battery
- AAAA type
- Run Time (Up To)
- 8 months
- Limited warranty - 1 year
