Kensington Kensington PresentAir Pro Bluetooth 4.0 LE Presenter - Black
Quicklinx: C1B5WS00 Mfr#: K72448WW
Featuring the latest in wireless technology, the PresentAir Pro Bluetooth 4.0 LE Presenter has everything you need to present with confidence and so much more. With USB ports at a premium on todays ultra-thin devices, the PresentAir Pro uses Bluetooth 4.0 LE technology to pair with your device. The PresentAir Pro buttons offer three modes Presenter, Media and Custom so you can select the button functions that work best for what youre doing. Download the free PresenterWorks app and discover all the options the Custom mode has to offer. The sleek design fits right in your pocket or you can place it into a pen/stylus holder. The presenter also works as a touch-activated stylus, and the red laser can call attention to any part of your presentation. The included carrying case provides convenient storage that protects the PresentAir Pro from scratches.
  • Bluetooth 4.0 LE technology
    The latest in wireless innovation, this low-energy pairing between your device and presenter frees up a valuable USB port and offers a range of up to 30 feet so you can move freely during a presentation.
  • Ultra-slim design
    The presenter's thin profile makes it extremely light and easy to hold, plus it can fit into a shirt pocket or the pen/stylus holder found in many business folios or briefcases.
  • Red laser pointer
    Make your point at the touch of a button with a bright red laser that can highlight any part of your presentation with complete effectiveness.
  • Touch-activated stylus
    Compatible with all major tablets and smartphones, holding the metal enclosure turns the presenter into a fully functional stylus to navigate your way around the touchscreen on your device.
Kensington PresentAir Pro Bluetooth 4.0 LE Presenter presentation remote control - black
Presentation remote control
Enclosure Colour
13.931 cm x 1.25 cm x 1.25 cm
18.5 g
Wireless Technology
Bluetooth
Max Operating Distance
10 m
AAAA type
1-year warranty
13.931 cm
1.25 cm
1.25 cm
18.5 g
Enclosure Colour
Wireless Technology
Bluetooth
10 m
Built-in laser pointer, built-in stylus, Bluetooth 4.0 LE, three modes, PresenterWorks
Operating System
Windows 8.1, iOS 8.0, Android 4.4
Carrying case
AAAA type
Run Time (Up To)
8 months
Limited warranty - 1 year
