Kensington FP215W 21.5" Privacy Screen
Quicklinx: CRKRWS00 Mfr#: K55797WW
£54.91 ex VAT
£65.89 inc VAT
Protect the sensitive information displayed on your monitor while also protecting your vision and the screen itself from scratches and fingerprints with a Privacy Screen for a Widescreen Monitor. Theyre great when you want to block wandering eyes that might be able to see whats on your desktop monitor. The thin privacy screen limits the field of vision to +/- 30 degrees and attaches with tab holders you place around the edge of your screen. The privacy screen also reduces harmful blue light by up to 30 percent.
  • Limited viewing angle
    Narrows the field of vision on the monitor to keep your information on the screen private, which is important when you are viewing confidential or sensitive information at your desktop.
  • Frameless tab holders
    Attaches to the edges of your monitor and lets you quickly and easily insert and remove the privacy screen without the need for sticky, messy adhesives of permanent applications.
  • Blue light reduction
    Filters harmful rays, which is helpful as blue light has been shown to interrupt sleep patterns and even cause retinal damage.
Kensington FP215W9 Privacy Screen for 21.5" Widescreen Monitors - 16:9 - display screen protector - 21.5" wide
Display screen protector - 2-way
Installation Type
Removable - adhesive
Package Content
Cleaning cloth
Display Screen Size Compatibility
21.5" wide
Package Content
Cleaning cloth
21.5" wide
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:9
Scratch Resistant
Brand: Kensington
