The FlexClip Copyholder holds copy, calendars, reminders, even keys any way you want. Easy-to-position flexible "gooseneck" arm allows for easy placement of paper in desired location.
- Kensington FlexClip - copy holder
- Product Type
- Copy holder
- Black
- Product Material
- Molded plastic
- 24.8 cm x 3.81 cm x 4.45 cm
- 70 g
- Portrait / landscape mode
- 1-year warranty
- Product Type
- Copy holder
- Product Material
- Molded plastic
- 24.8 cm
- 3.81 cm
- 4.45 cm
- 70 g
- Black
- Limited warranty: - 1 year
