Product
Kensington Easy Riser Notebook Cooling Stand With Smartfit
Customer rating: 5.0* (Write a review)
Quicklinx: 3XXFWS00 Mfr#: 60112
Device Type: Laptop
Type: Cooling
Device Screen Size: [N/A]
Colour: Grey, Purple
£10.71 ex VAT
£12.85 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
One size doesn't fit all. When it comes to comfort, fit is everything.
Complying with ergonomic standards doesnt have to be a pain. The Kensington SmartFit system eliminates the complication, confusion and high cost of giving your employees safe, comfortable, ergonomic workstations. Years of research from the US Army revealed a direct correlation between hand size and body measurements. The result is a simple colour-coding system that allows users to adjust for the perfect fit in seconds, every time, leaving you to deal with more important projects.
SmartFit demystifies ergonomics for individuals making it easy to install and customise their workspace accessories to their ergonomic comfort requirements.
Every SmartFit product includes a hand chart in the box. This indicates the specific SmartFit colour setting that will deliver optimum ergonomic comfort for the user.
A small investment in workplace ergonomics can generate significant rewards in productivity by reducing fatigue.
Kensington Easy Riser - notebook stand
Notebook stand
Notebook stand
Kensington Easy Riser Notebook Cooling Stand With Smartfit Bundle deal on Kensington Easy Riser Notebook Cooling Stand With Smartfit
£110.47
Resources
The following resources are available for the Kensington Easy Riser Notebook Cooling Stand With Smartfit
Customer reviews
Write a review for the Kensington Easy Riser Notebook Cooling Stand With Smartfit here!
Kensington Easy Riser Notebook Stand
Reviewed by Andrew. Review Posted 30/01/2008
I have bought a number of makes of laptop stands recently but this one stands out as the most portable, the most stable, the most practical and the most versatile. It can sometimes partially obscure ports on the front of the laptop, but this is true, and worse, with the other stands that we have.
Given the choice, this is the stand that our consultants put in their laptop bags.
By the way, I have not told anyone that this is also the least expensive - why shatter their illusions?
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Reviewed by Anonymous Review Posted 09/11/2007
Purchased for use as fold away unit when travelling, already have (much) more expensive desk unit.
Surprised by simplicity and durability, 3 height adjustments are good particularly display veiwing for small audience around desk.
Easy & very quick to set up/take down and pack.
Worth just as much as units 4 times the cost.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Device Type: Laptop
Type: Cooling
Colour: Grey
Colour: Purple
Brand: Kensington
Price Range Ex VAT: 0 - 50
