Kensington CV2000V USB-C Full HD VGA Adapter - Certified for use with Chromebook
Professional USB-C Video Adapter for VGA
A professional video adapter that allows you to extend your monitor to 1080p Full HD with your USB-C port. The adapter is ideal for expanding desktop productivity or connecting to video devices in a conference room, such as presentations.
Versatile video adapter
The adapter allows you to either mirror or extend the screen and it is also compatible with Thunderbolt 3 ports.
Full 1080p HD
Video expansion to a monitor, TV or projector that supports 1920 x 1200, so you get HD picture quality. For video output, the host device must support DisplayPort Alt mode via USB-C.
4K Ultra HD
This adapter gives you video expansion to a monitor, TV or projector via the crystal-clear resolution of 4K Ultra HD. It's also backward compatible with 1080p Full HD so you can just as easily connect to legacy monitors. -
Extend or mirror modes
Extend mode allows you to drag an open application to an external monitor so you can work across multiple screens, while mirror mode allows you to replicate the content that's on your computer display to an external screen. -
Plug-and-Play
Simply plug in the adapter and it will run automatically without the need for drivers or software downloads. -
High-quality construction
Using high-quality components means that you'll know your adapter will perform when you need it to and is completely safe to use with your USB-C laptop, 4K monitor, TV or projector.
- Kensington CV4000H USB-C 4K HDMI Adapter - adapter - HDMI / USB
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 30 Hz
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- HDMI - female
- Thunderbolt 3
- 4K support, active adapter
- Works With Chromebook
- 2-year warranty
- Cable Type
- Adapter 4K support, active
- Interface Supported
- HDMI / USB
- Thunderbolt 3
- DisplayPort Alternate Mode support
Adapters & Converters
- Refresh Rate
- 30 Hz
- OS Required
- Apple MacOS X 10.10 or later, Windows 8.1 / 10, Google Chrome OS 44 or later
- Connector
- 19 pin HDMI Type A - female
- Plug and Play, RoHS 2011/65/EU, IEC 61000-4-2:2008, EN 55024:2010+A1:2015, Directive 2014/30/EU, IEC 61000-4-4:2012, IEC 61000-4-6:2013, IEC 61000-4-3:2006+A1:2007+A2:2010
- Limited warranty - 2 years
