Kensington CV2000V USB C HD VGA Adapter
Quicklinx: CRJ7WS00 Mfr#: K33994WW
£17.36 ex VAT
£20.83 inc VAT
Kensington CV2000H USB-C to VGA HD Video Adapter
A professional-level video adapter that allows you to extend your display to 1080p Full HD from your USB-C port. The adapter is ideal for desktop productivity expansion, or connecting to the video equipment in a conference room for a presentation. The adapter offers extend mode or mirror mode and is also compatible with Thunderbolt 3 ports.
Full 1080p HD*
Video expansion to a monitor, TV or projector that supports 1920x1200 so you get clear, high definition picture quality when you’re displaying at your desk or in a conference room.
*For video output, the host device must support DisplayPort Alt Mode over USB-C.
Extend or Mirror Modes
Extend mode allows you to drag an open application to an external monitor so you can work across multiple screens, while Mirror mode allows you to replicate the content that’s on your computer display to an external screen.
Thunderbolt 3 Compatible
Can connect to laptops and tablets that have Thunderbolt 3 ports.
Plug and Play
Simply plug in the adapter and it will run automatically without the need for drivers or downloads.
Premium Construction
Using high-quality components means that you’ll know your adapter will perform when you need it to and is completely safe to use with your valuable laptop and HD monitor or TV.
  • Full 1080p HD
    This adapter gives you video expansion to a monitor, TV or projector so you get clear, high-definition picture quality when you're displaying at your desk or in a conference room.
  • Extend or mirror modes
    Extend mode allows you to drag an open application to an external monitor so you can work across multiple screens, while mirror mode allows you to replicate the content that's on your computer display to an external screen.
  • Plug-and-Play
    Simply plug in the adapter and it will run automatically without the need for drivers or software downloads.
  • High-quality construction
    Using high-quality components means that you'll know your adapter will perform when you need it to and is completely safe to use with your USB-C laptop, HD monitor, TV or projector.
Kensington CV2000V USB-C HD VGA Adapter - adapter - VGA / USB
Cable
Adapter - VGA / USB
Max Output Resolution
1920 x 1200
Connector
24 pin USB-C - male
Connector (Second End)
HD-15 (VGA) - female
Thunderbolt 3
1080p support, active adapter
Works With Chromebook
Cable Type
Adapter 1080p support, active
Interface Supported
VGA / USB
Thunderbolt 3
DisplayPort Alternate Mode support
Adapters & Converters
1920 x 1200
Apple MacOS X 10.10 or later, Windows 8.1 / 10, Google Chrome OS 44 or later
Connector
24 pin USB-C - male
15 pin HD D-Sub (HD-15) - female
Plug and Play, RoHS 2011/65/EU, IEC 61000-4-2:2008, EN 55024:2010+A1:2015, Directive 2014/30/EU, IEC 61000-4-4:2012, IEC 61000-4-6:2013, IEC 61000-4-3:2006+A1:2007+A2:2010
