Kensington CV2000V USB C HD VGA Adapter
Quicklinx: CRJ7WS00 Mfr#: K33994WW
£17.80 ex VAT
£21.36 inc VAT
A professional-level video adapter that allows you to extend your display to 1080p Full HD from your USB-C port. The adapter is ideal for desktop productivity expansion, or connecting to the video equipment in a conference room for a presentation. The adapter offers extend mode or mirror mode and is also compatible with Thunderbolt 3 ports.
  • Full 1080p HD
    This adapter gives you video expansion to a monitor, TV or projector so you get clear, high-definition picture quality when you're displaying at your desk or in a conference room.
  • Extend or mirror modes
    Extend mode allows you to drag an open application to an external monitor so you can work across multiple screens, while mirror mode allows you to replicate the content that's on your computer display to an external screen.
  • Plug-and-Play
    Simply plug in the adapter and it will run automatically without the need for drivers or software downloads.
  • High-quality construction
    Using high-quality components means that you'll know your adapter will perform when you need it to and is completely safe to use with your USB-C laptop, HD monitor, TV or projector.
Kensington CV2000V USB-C HD VGA Adapter - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
VGA
Enclosure Colour
Bus Type
USB-C
Max Resolution
1920 x 1200
VGA
Thunderbolt 3 compatible
Google Chrome OS, Apple MacOS X 10.10, Apple MacOS X 10.11, Windows 8.1 / 10
Plug and Play
Enclosure Colour
Brand: Kensington
Price Range Ex VAT: 0 - 50
