The contour panel is engineered to bring weight closer to the body o reduce shoulder and back fatigue by up to 35%.
- Kensington Contour Roller - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Ballistic nylon
- 465 mm x 230 mm x 360 mm
- 3.2 kg
- Notebook Compatibility
- 17"
- Carrying Strap
- Shoulder carrying strap
- Telescopic Handle / Wheels
- 3-year warranty
- Product Type
- Product Material
- Ballistic nylon
- 465 mm
- 230 mm
- 360 mm
- 3.2 kg
- 17"
- Notebook Compatibility Dimensions
- 41 cm x 29 cm x 4 cm
- Carrying Strap
- Black
- Limited warranty: - 3 years
