Designed in collaboration with Microsoft , the Combination Lock for Surface Pro and Surface Go delivers uncompromised security. Non-invasive locking technology is supported by a secure carbon steel cable. From Kensington, inventor and worldwide leader in laptop security locks.
Exclusively designed for Surface
Kensington worked directly with Microsoft to provide professional-level security and superior device engagement, so you can secure your Surface Pro or Surface Go with confidence. -
An easy-to-use security solution that requires no device modifications, preserving the Surface Pro's hardware warranty and aesthetics. -
Strong lock head
Tested for torque/pull, foreign implements, lock lifecycle, corrosion, strength, and other environmental conditions, this lock head meets Kensington's industry-leading standards for tamper resistance, reliability, and durability. -
Carbon steel cable
Six foot (1.8m) plastic sheath-covered cable resists tampering and offers the same level of cut-resistance and theft-deterrence as thicker cables. -
Register & Retrieve
Free quick, secure online code registration program.
- Kensington Combination Lock - security cable lock
- Product Type
- Security cable lock
- Product Material
- Carbon steel
- Length
- 1.8 m
- 190 g
- Tamper-proof, anti-theft protection, cut-resistant, non-invasive
- Localisation
- Europe
- 2-year warranty
- Designed For
- Microsoft Surface Go, Pro (Mid 2017)
- Product Type
- Product Material
- Carbon steel
- Length
- 1.8 m
- Diameter
- 4.3 mm
- 190 g
- Localisation
- Europe
Security Cable Lock
- Intended For
- Tablet
- Lock Method
- Combination
- Limited warranty - 2 years
- Designed For
