When combined with the Kensington Charge & Sync Cabinet, this 10-pack of USB to 30-pin cables allows you to keep up to ten iPad charged and ready for anther day in the classroom. They're designed to fit perfectly with the Cabinets built-in USB ports.
- Kensington charging / data cable - 16.5 cm
- Cable
- Charging / data cable
- Packaged Quantity
- 10 (specifications are for single item)
- Length
- 16.5 cm
- Black
- Connector
- Apple Dock - male
- Connector (Second End)
- USB - male
- Sync and charge
- 2-year warranty
- Designed For
- Apple iPod (4G, 5G); iPod classic; iPod mini
- Packaged Quantity
- Cable Type
- Length
- 16.5 cm
- Sync and charge
- Black
- Connector
- Apple Dock connector - male
- 4 pin USB Type A - male
- Limited warranty - 2 years
- Designed For
- Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
