Your basket is empty
Kensington Charge & Sync USB to 30 pin (10 Pack)
Need a Mobile Tariff ??? See Description Below
Quicklinx: 8QWVWS00 Mfr#: K67780WW
Device Type: iPad
Type: Charging
Device Screen Size: [N/A]
3 in stock
£42.61 ex VAT
£51.13 inc VAT
Standard delivery Delivered within 3-5 working days
When combined with the Kensington Charge & Sync Cabinet, this 10-pack of USB to 30-pin cables allows you to keep up to ten iPad charged and ready for anther day in the classroom. They're designed to fit perfectly with the Cabinets built-in USB ports.
Kensington charging / data cable - 16.5 cm
Cable
Charging / data cable
Packaged Quantity
10 (specifications are for single item)
Length
16.5 cm
Connector
Apple Dock - male
Connector (Second End)
USB - male
Sync and charge
2 years warranty
Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Packaged Quantity
Cable Type
Length
16.5 cm
Sync and charge
Connector
Apple Dock connector - male
4 pin USB Type A - male
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPhone 3G, 3GS, 4, 4S , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G) , Apple iPod touch (1G, 2G, 3G, 4G)
Device Type: iPad
Type: Charging
Brand: Kensington
Price Range Ex VAT: 0 - 50
