Your basket is empty
Kensington Charge & Sync Trolley for iPad
Quicklinx: 8LV6WS00 Mfr#: K67771EU
With space for 10 iPads and the ability to stack up to 3 cabinets, the Kensington Charge & Sync Cabinet is the smart solution. Each iPad cabinet is secured to a table with the included mounting plate or a cable lock. To simplify charging and syncing, youll find easy access to each iPad or iPad mini 30-pin or Lightning cable connector port (cable not included). A single power cord provides charging for the entire cabinet. Theres even a built-in fan to keep your iPads cool.
Kensington Charge & Sync Cabinet - cabinet unit
Cabinet unit
Integrated Devices
Fan
Europe
Recommended Use
10 tablets
Charcoal
1 year warranty
Apple iPad (3rd generation); iPad 1; 2
Charcoal
Europe
AV Furniture
Cabinet unit
Recommended Use
10 tablets
Integrated Devices
Fan
Syncronisation & charge, locking front door
Limited warranty - 1 year
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2
