Kensington CH1000 USB-C 4-Port Hub, USB 3.1 Gen
Quicklinx: BZ87WS00 Mfr#: K33995WW
Type: USB
Ports: 4
Hurry, only 1 left in stock!
£25.67 ex VAT
£30.80 inc VAT
The CH1000 USB-C 4-Port Hub is the simple, easy way to expand the connectivity of your USB-C device. Connect your peripherals like a mouse, keyboard or flash drive using the three USB-A ports, while using the single USB-C port to connect a smartphone or tablet that features the new style of port. The hub offers USB 3.1 Gen 1 technology, supporting data transfer speeds up to 5 Gbps. With Plug & Play installation, all your accessories will be up and running quickly, and the compact design means it can be easily packed up and taken with you on the road.
Kensington CH1000 - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x USB-C
Google Chrome OS, Windows 8, Windows 8.1, Apple MacOS X 10.10, Windows 10
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
3 x USB 3.0 Type A , 1 x micro-USB 3.1 Type C , 1 x micro-USB 3.1 Type C
Plug and Play
Limited warranty - parts and labour - 2 years
BZ87 C2G USB 3.0 to Gigabit Ethernet Network Adapter In Stock £23.69
Type: USB
Ports: 4
Brand: Kensington
Price Range Ex VAT: 0 - 50
