Kensington CA1000 USB-C to USB-A Adapter
Quicklinx: BZ7PWS00 Mfr#: K33992WW
Length: [N/A]
£9.10 ex VAT
£10.92 inc VAT
The first wave of USB-C products are here and Kensington is making sure you have the adapter to keep your standard USB accessories up and running. The CA1000 USB-C to USB-A Adapter allows you to connect your USB-C device to a keyboard, mouse, hard drive or other peripheral accessory with a standard USB-A port. The adapter has a reversible connector and supports charging up to 3 AMPs. You can also transfer data up to 5 Gbps, and with Plug & Play installation, youll be connected quickly and easily.
Kensington CA1000 - USB-C adapter - USB to 24 pin USB-C
USB-C adapter
Molded, sync and charge
Connector
4 pin USB Type A - female
Connector (Second End)
24 pin USB-C - male
USB 3.1
USB-C adapter
Connector
24 pin USB-C - male
USB 3.1, Plug and Play, RoHS, halogen-free
Length: [N/A]
Brand: Kensington
