When youre on the road and need to power your device, the Kensington 5200 USB Mobile Charger is the perfect answer to boost a drained battery. The mobile charger features a 5200 mAh battery that has enough reserve power to fully charge an iPhone 6 Plus or a Galaxy S5. The high-grade LG battery cell and high-quality components ensure your device charges safely and efficiently. With PowerWhiz Technology, the charger automatically detects your device and provides the fastest charge possible. A stylish aluminum cover finish creates a professional look and the 4-LED display lets you know how much power is left in the charger. The power bank can be used with a wide variety of devices including all Apple products, most Android smartphones and tablets, and many other USB-charged devices.
5200 mAh battery
Powerful capacity when you need to charge your smartphone or tablet and there's no traditional outlet to get plugged in. It provides a full charge to either an iPhone 6 Plus or Galaxy S5. -
2.1 AMP output
Quickly charges tablets and smartphones at full speed so you can get your device's battery powered up and ready to go. -
PowerWhiz technology
An internal smartchip automatically detects your mobile device and provides the correct amps for a fast, safe charge so you can power up quickly. -
Aluminum finish
The stylish cover offers a premium look and feel that provides a level of sophistication that goes beyond the traditional black finish. -
4-LED display
The lights indicate how much battery power remains in the mobile charger so you know when it's time to refill the charger. -
Wide-ranging compatibility
The mobile charger can be used with all iPhones and iPads, most Android smartphones and tablets, plus many other USB-charged devices.
- Kensington Power Bank 5200 Mobile Charger power bank x 18650 - Li-Ion - USB
- Product Type
- Power bank
- 5.5 cm x 9.1 cm x 2.2 cm
- 152.4 g
- Silver
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2.1 A
- Battery
- 18650 - Lithium Ion - 5200 mAh
- Power Device Details
- - 4 pin USB Type A - 5 V - 2.1 A
- Cables
- Micro-USB charge cable
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 5.5 cm
- 9.1 cm
- 2.2 cm
- 152.4 g
- Enclosure Colour
- Silver
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.1 A
- PowerWhiz technology
- 18650
- Technology
- Lithium Ion
- Voltage Provided
- 5 V
- Capacity
- 5200 mAh
- Circuit protection, battery level indicator
- Cables Included
