Kensington Brushed Aluminium 2.1A 5200mAh USB Mobile Charger
Quicklinx: B5VWWS00 Mfr#: K38220WW
When youre on the road and need to power your device, the Kensington 5200 USB Mobile Charger is the perfect answer to boost a drained battery. The mobile charger features a 5200 mAh battery that has enough reserve power to fully charge an iPhone 6 Plus or a Galaxy S5. The high-grade LG battery cell and high-quality components ensure your device charges safely and efficiently. With PowerWhiz Technology, the charger automatically detects your device and provides the fastest charge possible. A stylish aluminum cover finish creates a professional look and the 4-LED display lets you know how much power is left in the charger. The power bank can be used with a wide variety of devices including all Apple products, most Android smartphones and tablets, and many other USB-charged devices.
  • 5200 mAh battery
    Powerful capacity when you need to charge your smartphone or tablet and there's no traditional outlet to get plugged in. It provides a full charge to either an iPhone 6 Plus or Galaxy S5.
  • 2.1 AMP output
    Quickly charges tablets and smartphones at full speed so you can get your device's battery powered up and ready to go.
  • PowerWhiz technology
    An internal smartchip automatically detects your mobile device and provides the correct amps for a fast, safe charge so you can power up quickly.
  • Aluminum finish
    The stylish cover offers a premium look and feel that provides a level of sophistication that goes beyond the traditional black finish.
  • 4-LED display
    The lights indicate how much battery power remains in the mobile charger so you know when it's time to refill the charger.
  • Wide-ranging compatibility
    The mobile charger can be used with all iPhones and iPads, most Android smartphones and tablets, plus many other USB-charged devices.
Kensington Power Bank 5200 Mobile Charger power bank x 18650 - Li-Ion - USB
Power bank
5.5 cm x 9.1 cm x 2.2 cm
152.4 g
Silver
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Max Electric Current
2.1 A
18650 - Lithium Ion - 5200 mAh
Power Device Details
- 4 pin USB Type A - 5 V - 2.1 A
Cables
Micro-USB charge cable
Power bank
Tablet, mobile phone
5.5 cm
9.1 cm
2.2 cm
152.4 g
Enclosure Colour
Silver
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
2.1 A
Lithium Ion
Voltage Provided
5 V
5200 mAh
Circuit protection, battery level indicator
