Your basket is empty
Kensington Brushed Aluminium 2.1A 5200mAh USB Mobile Charger
Quicklinx: B5VWWS00 Mfr#: K38220WW
When youre on the road and need to power your device, the Kensington 5200 USB Mobile Charger is the perfect answer to boost a drained battery. The mobile charger features a 5200 mAh battery that has enough reserve power to fully charge an iPhone 6 Plus or a Galaxy S5. The high-grade LG battery cell and high-quality components ensure your device charges safely and efficiently. With PowerWhiz Technology, the charger automatically detects your device and provides the fastest charge possible. A stylish aluminum cover finish creates a professional look and the 4-LED display lets you know how much power is left in the charger. The power bank can be used with a wide variety of devices including all Apple products, most Android smartphones and tablets, and many other USB-charged devices.
Kensington Power Bank 5200 Mobile Charger - power bank x 18650 Li-Ion
Power bank
5.5 cm x 9.1 cm x 2.2 cm
152.4 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
18650 - Lithium Ion 5200 mAh
Power Device Details
- 4 pin USB Type A - 5 V - 2.1 A
Cables
Micro-USB charge cable
Power bank
5.5 cm
9.1 cm
2.2 cm
152.4 g
Enclosure Colour
Silver
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2.1 A
PowerWhiz technology
Lithium Ion
Voltage Provided
5 V
5200 mAh
Circuit protection, battery level indicator
