Kensington AC12 Security Charging Cabinet
Quicklinx: C7WSWS00 Mfr#: K64415EU
£720.58 ex VAT
£864.69 inc VAT
With more tablets, and 2-in-1 hybrids, being deployed in classrooms, healthcare offices and retail or hospitality businesses, the need for a solution, that can store, charge and secure those devices overnight is greater than ever. The AC12 security charging cabinet features slide-out drawers, that provide an easier check-in/check-out experience for teachers or administrators. The cabinet holds 12 devices, and with the cabinet running on AC power, it can safely charge all 12 devices simultaneously.
  • Ample storage and AC power
    Cabinet holds up to 12 devices, where they can be securely stored for charging. Rugged dividers with convenient cable routing help manage cord clutter.
  • Tamper-resistant door
    Complete with a Kensington lock, the front door swings wide for easy access to the cabinet interior.
  • Universal-device design
    The cabinet accommodates a wide variety of devices, including the tablets, laptops and more.
  • Sliding drawers
    Each drawer partially slides out, so you can easily place your device into the cabinet.
  • Free-spinning wheels
    The cabinet can be rolled in any direction and rotates 360 degrees, making it extremely easy to maneuver in tight spaces
  • Dual wheel locks
    Locking foot pedals on the two front wheels can be engaged with a simple push downward to severely limit movement. Lift the pedals to unlock, and the wheels once again move freely.
Kensington AC12 Security Charging Cabinet - cabinet unit
Cabinet unit - lockable
42 cm x 59 cm x 71.5 cm
35.4 kg
Europe
Recommended Use
12 tablets / notebooks
Outlets Qty
12
Doors
Swinging
Wheels Qty
4
Package Content
Power cord
42 cm
59 cm
71.5 cm
35.4 kg
Europe
Package Content
Power cord
AV Furniture
Cabinet unit
Recommended Use
Doors
Swinging
Drawers Qty
12
Cable Management
Integrated cable management
Lockable
Wheels Qty
4
Brakes Qty
2
Doors Qty
1
Lock Type
Key
Details
Sync and charge
Power Provided
90 Watt
Outlets Qty
12
Dimensions & Weight Details
Dimensions
Drawer - width: 25.4 cm, depth: 35.4 cm, height: 4.5 cm
Kensington AC12 Security Charging Cabinet Bundle deal on Kensington AC12 Security Charging Cabinet
£820.34
Brand: Kensington
Price Range Ex VAT: 500 - 750
