Kensington 24" Privacy Screen (16:10)
Quicklinx: CRKMWS00 Mfr#: K52794WW
£63.66 ex VAT
£76.39 inc VAT
Trust Kensington, the choice of IT professionals, to help protect the sensitive information on a monitor and reduce the chances of wandering eyes viewing confidential data. FP Series Privacy Screens limit the field of vision to +/- 30 degrees so a person off to the side only sees a dark screen. They are easy to install with either the included frameless tab holders or double-sided tape. The reversible privacy screens also use an anti-reflective coating to reduce glare, and they filter out harmful blue light by up to 30 percent.
Kensington FP240W Privacy Screen for 24-inch Widescreen Monitors - 16:10 - display privacy filter - 24" wide
Display privacy filter
Package Content
Cleaning cloth
Display Screen Size Compatibility
24" wide
Package Content
Cleaning cloth
24" wide
Monitor Filter
Aspect Ratio
16:10
Scratch Resistant
Anti-reflective, matte, reversible, antimicrobial finish, 30° visible angle, scratch-resistant, glossy surface
Kensington 24 Bundle deal on Kensington 24" Privacy Screen (16:10)
£162.83
Brand: Kensington
Price Range Ex VAT: 50 - 100
