Combining comfort and convenience, the award-winning SmartFit Laptop Riser with Wireless Phone Charging Pad blends 20 years of ergonomic expertise with the latest in reliable wireless charging technology. Lift your laptop up to eye level to relieve neck and back strain, then use the lower platform to wirelessly charge your phone. The SmartFit system allows you to find your personal comfort color and self-fit the riser to your ideal height. It also utilizes Zero Footprint mounting so you can mount any compatible Kensington universal dock underneath the laptop platform, keeping your desktop less cluttered.
Qi wireless charging pad
Power your smartphone or other Qi-enabled wireless charging device with a dedicated wireless charging pad that is always on. Simply set your compatible device on the pad and watch its battery fill up. -
SmartFit system
Allows you to select your personal height setting using the included color-coded fitting chart so you can set the riser at your personalized height. -
Height-adjustable
Raise or lower the platform to your custom height, placing the laptop screen at eye level which helps ease neck and back discomfort while working at your desktop. -
Zero footprint enabled
Allows you to mount a compatible Kensington universal docking station under the platform, which is ideal for desktops with limited space. -
Cable management
Unique design under the laptop platform allows you to route cords in a clutter-free way, producing a cleaner desktop experience. -
Anti-skid tilt design
Ideally angled so any laptop up to 15.6" and 3.5kg is cradled in stability on the platform. -
Kensington Security Slot
Add a ClickSafe or MicroSaver lock to either the right or left leg of the stand to lock it down and keep the riser safe from theft.
- Kensington SmartFit Laptop Riser with Wireless Phone Charging Pad - notebook stand
- Product Type
- Notebook stand
- Black
- 17.8 cm x 25.1 cm x 24.3 cm
- 1.18 kg
- Notebook Compatibility
- 15.6"
- Integrated cable management, anti-skid grip, SmartFit, Qi Wireless Charging, kensington security slot, Zero Footprint Mounting
- 1-year warranty
- Product Type
- Notebook stand
- 17.8 cm
- 25.1 cm
- 24.3 cm
- 1.18 kg
- 15.6"
- Black
- Weight Limit
- 3.49 kg
- Limited warranty: - 1 year
