KAZAM Life B4 (2.2 inch) TFT Display VGA Camera Mobile Phone
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9QV1WS00 Mfr#: LFB44300C0-04
  • microSD
  • Android
  • Bluetooth
Stylish design incorporates large well spaced keys and large menu icons, ideal if you struggle with touchscreens. With easy access to contacts, camera, volume, torch and key lock, plus a dedicated smart SOS button, this device puts features at your finger tips.
HELP IS AT HAND
From both KAZAM and your friends and family
Of course KAZAM is here if you have any issues with your phone, but we have made getting personal support easy too. With a dedicated smart SOS button you are a button press away from contacting the people you need in an emergency. The phone will call your support network, if it gets a voicemail it will call the next person.
FORM MEETS FUNCTION
Great design is for everyone
Stylish design and a premium finish make this phone easy on the eye, with large well spaced buttons it makes it easy on the fingers too.
SMALL WITH A WHOLE LOT GOING ON
The quick access buttons provide fast access to the camera, making it accessible when you need it. With a torch and smart SOS button this device has features that look out for you.
VGA MAIN CAMERA
A great camera for quick snaps when you are out and about, the KAZAM Life B4 even has video record and playback for when a still picture isn't enough.
  • Help is at hand
    Of course KAZAM is here if you have any issues with your phone, but KAZAM have made getting personal support easy too. With a dedicated smart SOS button you are a button press away from contacting the people you need in an emergency. The phone will call your support network, if it gets a voicemail it will call the next person.
  • Form meets function
    Stylish design and a premium finish make this phone easy on the eye, with large well-spaced buttons it makes it easy on the fingers too.
  • Small with a whole lot going on
  • VGA main camera
Kazam Life B4 - dark grey - feature phone - GSM
Feature phone
Display
220 x 176 pixels - 2.2" - TFT
FM radio, LED flashlight
Supported Memory Card
microSD slot - up to 16 GB
Service Provider
Not specified
Bar
Wireless Interface
Bluetooth
Messaging Services
SMS, MMS
Dark grey
49 mm x 12.6 mm x 124 mm
Feature phone
Bar
Integrated Components
49 mm
12.6 mm
124 mm
Body Colour
Dark grey
Cellular
GSM
Service Provider
Not specified
Messaging & Internet
Messaging Services
SMS, MMS
Communications
2G Band
900 GSM, 1800 GSM
Wireless Interface
Bluetooth
Phone Features
Phone Functions
Speakerphone, call timer, vibrating alert
Additional Features
SOS button
Organiser
Personal Information Management
Calendar, calculator, alarm clock
User Memory
250 KB
Supported Flash Memory Cards
microSD - up to 16 GB
Main Camera
Video Resolutions
640 x 480 (VGA)
Display
TFT
Diagonal Size
2.2"
Display Resolution
220 x 176 pixels
Lithium Ion
800 mAh
Power adapter
