Kaiser Baas X100 Sports Camera 1080p
Quicklinx: CL56WS00 Mfr#: KBA12009
With a recording resolution of 1080p HD at 30 frames per second and a wide-angle field of view at 150 degrees, the X100 Action Camera consistently produces clear, focused footage that is fantastic to view. The X100 Action Camera with Wi-Fi lets you view, download and share your footage with ease and the Wrist Remote allows for control of recording without having to play around with the setup of the X100.
The X100 Action Camera with W-iFi lets you view, download and share your footage with ease and the wrist remote allows for control of recording without having to play around with the setup of the X100.
  • Waterproof case
    Take your X100 with you everywhere you go, whether you're on the ground, in the sky or underwater. The Waterproof case will keep your camera dry in any situation up to a depth of 30 m.
  • Full HD video
    Capture your experiences in 1080p and get the most out of your X100. Watch your footage on TV via the mini HDMI port.
  • Wi-Fi connectivity
    Use your smart device to frame up your shots and playback footage with the X100 app so you never go home uncertain.
  • Built-in display
    The X100 comes fitted with a 2-inch LCD screen so you can perfectly frame your shots. Built with clarity in mind, the X100 won't ever leave you stuck with over-saturated footage or stills.
Kaiser Baas X100 - action camera
Action camera - 1080p
Action Camera Type
Mountable
Memory Card Slot
microSD card
Wireless Interface
Wireless LAN
Sensor Resolution
5.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens 2.65 mm f/2.5
Focus Adjustment
Focus free
Min Focus Distance
50 cm
Display
LCD display - 2"
Supported Battery
Li-ion rechargeable battery - 1060 mAh (included)
HDMI, USB 2.0
5.4 cm x 3.7 cm x 5.1 cm
77 g
Camcorder Sensor Resolution
5.0 MP
Camcorder Interpolated Photo Resolution
12.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.5"
Frame Rate (Max Resolution)
30 fps
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1920 x 1080
HDMI, USB 2.0, Wireless LAN
Exposure & White Balance
Light Sensitivity
ISO auto (100-200)
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (warm white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/30 sec
Lens System
Wide-angle lens 2.65 f/2.5
Focus Adjustment
Focus free
Min Focus Distance
50 cm
Max View Angle
150 degree(s)
Additional Features
Self-Timer Delay
Additional Features
Auto power save, date/time stamp, Time-Lapse recording, Loop recording
Action Camera Features
Camera Type
Mountable
Display
2" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , HDMI output
USB cable, mounting screw, underwater housing, curved adhesive mount, 2 adhesive pads, flat adhesive mount, remote control wristband, quick release mount
Protection
Waterproof
Underwater Use
Underwater Depth
Up to 30 m
Battery Type
Lithium Ion - manufacturer-specific
Details
Battery Life Details
Video recording - 1.33 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Included
No
Memory Card Max Supported Size
32 GB
Video Capture
1920 x 1080 p - 30 fps , 1280 x 720 p - 60 fps , 1280 x 720 p - 30 fps
5.4 cm
3.7 cm
5.1 cm
77 g
