Your basket is empty
Juniper 100 with 8xFE ports
Quicklinx: B36BWS00 Mfr#: SRX100H2
Ports: 8
£310.00 ex VAT
£372.00 inc VAT
The Juniper Networks SRX100 Services Gateway offers features that provide complete functionality and flexibility for delivering secure Internet and intranet access. The services gateway offers stable, reliable, and efficient IP routing in addition to switching support and LAN connectivity. The device provides Internet Protocol Security (IPsec), virtual private network (VPN), and firewall services for small-sized and medium-sized companies and enterprise branch and remote offices. The SRX100 Services Gateway can be connected directly to a traditional private networks such as leased lines, frame relay, or Multi Protocol Label Switching (MPLS) networks or to the public Internet.
Juniper Networks SRX100 Services Gateway - security appliance
Security appliance
Rack-mountable - 1U
RAM
2 GB
Flash Memory
2 GB
Ports Qty
8
Ethernet, Fast Ethernet, RS-232, X.21, V.35, RS-449
Performance
Firewall throughput (large packets): 700 Mbps , Firewall throughput (IMIX): 200 Mbps , Firewall throughput (64-byte packet size): 70 Kpps , Firewall throughput (HTTP): 100 Mbps , VPN throughput (IPSec): 65 Mbps , Firewall throughput: 90 Mbps , IPS throughput: 75 Mbps , Antivirus throughput: 25 Mbps , Connection rate: 1800 connections per second , Routing throughput: 100 Kpps
IPSec VPN tunnels: 128 , Concurrent sessions: 32000 , Security policies: 384 , Maximum number of users: unlimited , BGP instances: 5 , BGP peers: 8 , BGP routes: 8000 , OSPF instances: 4 , OSPF routes: 8000 , RIP instances: 4 , RIP routes: 8000 , Static routes: 8000 , Concurrent VPN tunnels: 128 , VPN tunnel interfaces: 10 , Maximum number of remote users: 25 , Security zones: 10 , Virtual routers: 3 , Virtual interfaces (VLANs): 16 , Maximum number of access points: 4
JUNOS
21.6 cm x 14.7 cm x 3.6 cm
1.1 kg
Security appliance
Height (Rack Units)
1U
21.6 cm
14.7 cm
3.6 cm
1.1 kg
Processor / Memory / Storage
RAM
2 GB
Flash Memory
2 GB
Rack-mountable
Ports Qty
8
Wired
Network / Transport Protocol
RSVP, IPSec, PPPoE, SMTP, FTP, DHCP, POP3, IMAP
Routing Protocol
OSPF, IS-IS, RIP-1, RIP-2, BGP, IGMPv2, IGMP, DVMRP, VRRP, PIM-SM, PIM-DM, IGMPv3, GRE, OSPFv3, PIM-SSM, MSDP, ECMP, RIPng, MLD, MPLS
Performance
Firewall protection, Layer 2 switching, NAT support, VPN support, PAT support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, content filtering, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), firmware upgradable, DDos attack prevention, Weighted Random Early Detection (WRED), Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, anti-spam protection, Quality of Service (QoS), DHCP server, IPv4 support, fanless, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), role based access control, J-Flow, static routing, policy based access control, tagged VLAN
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, DH, SHA-1, DSA, PKI, 128-bit AES, 256-bit AES, IKEv2, SHA-2, 256-bit SHA
Authentication Method
SecurID, RADIUS, X.509 certificates, LDAP, XAUTH authentication
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1ad
8 x 100Base-TX - RJ-45 , 1 x USB - Type A
Rack Mounting Kit
Included
MTBF
24.8 years
FCC Class B certified, CTR 21, ICSA IPSec certified, ICSA Firewall certified, CISPR 22 Class B, EN55022 Class B, CB, AS/NZS 60950-1, EMC, DOC, CS-03, FIPS 140-2, EN300-386, UL 60950-1, EN 60950-1, ICES Class B, EAL 4, NEBS, CAN/CSA C22.2 No. 60950-1, TIA/EIA/IS-968, AS/ACIF S002, EMI, VCCI Class B, AS/ACIF S043.1:2003, AS/ACIF S043.2:2006
Internal power supply
10 Watt
Power Provided
30 Watt
JUNOS
10 - 90% (non-condensing)
Ports: 8
Brand: Juniper
Price Range Ex VAT: 300 - 500
