Juice Wireless Charger Disc - 5W White
Quicklinx: FKPPWS00 Mfr#: JUI-WCHAR-DISC-5W-WHT
Introducing the Juice Disc wireless charger
A 5Watt wireless pad that is perfect for charging the Samsung S10/S9/S8, Huawei P30/P30 Pro or the iPhone X/8 phones, or any device with Qi wireless charging. Simply place your compatible device onto the pad and walk away. No more fighting to get the cable into the charging port!
In order to use the Juice Disc you will also need a micro USB cable and mains adaptor.
Typical charging times:
iPhone8 (1.5hr for 0-50% charge) (3hr for 0-100% charge)
iPhone 8+ (under 2hr for 0-50% charge) (under 4hr for 0-100% charge)
iPhone X (under 2hr for 0-50% charge) (under 4hr for 0-100% charge)
Samsung S10/S8/S9 (2hr for 0-50% charge) (4hr for 0-100% charge)
Instructions: Connect the cable to the pad, Plug the cable into a wall charger, Place your compatible mobile onto the pad and walk away. At Juice we decided to limit the amount of accessories supplied with our wireless chargers in order to reduce product waste, as we are sure you may already have a micro USB cable and wall charger at home.
Juice wireless charging pad - 5 Watt
Wireless charging pad
10 cm x 10 cm x 1 cm
100 g
White
Power Provided
5 Watt
Mobile phone
10 cm
10 cm
1 cm
100 g
Enclosure Colour
White
Input Connectors
5 pin Micro-USB Type B
Power Provided
5 Watt
Wireless Charging
