Product
JBL Soundgear Wearable Wireless Sound
Quicklinx: DBF9WS00 Mfr#: JBLSOUNDGEARBABLK
Speaker Type: Speaker
Connection: Wireless
Hurry, only 2 left in stock!
£166.66 ex VAT
£199.99 inc VAT
Thanks to the JBL signature sound wireless performance and the Quad transducers with Bass boost, the Soundgear BTA creates your own personal sound zone while allowing you to remain fully aware of your surroundings. The around-the-neck construction, ergonomic shape, intuitive controls, and soft touch fabric finish provide a hands-free and ears-free audio experience unlike any you've ever had before. Bluetooth-enabled for sound streaming from compatible devices, the JBL Soundgear BTA offers long-lasting playback time, a quick recharge and an echo-canceling dual mic for crystal clear calls. The included TV Bluetooth wireless audio transmitter enables a convenient connection to the TV to better immerse yourself in a movie. Whether you want to give your VR experience a boost with immersive audio, watch a video, add music to your daily activities around the house or take a conference call, the JBL Soundgear provides you with an exciting, pervasive sound experience with total freedom and comfort.
  • JBL signature sound
    Enjoy an enriched and immersive audio experience that JBL sound can provide, thanks also to the Quad transducers with Bass boost.
  • Dual mic conferencing
    Hands-free, crystal clear voice calls make your conference calls easy and convenient, free from echo and noise.
  • Hands-free and ears-free
    Cut the cords and conveniently stream all your content wirelessly and hands-free, staying aware of your surroundings, without disturbing the others.
  • BTA, wireless audio transmitter
    Enables a convenient Bluetooth connection to the TV to better immerse yourself in a movie. Enjoy a synchronized audio experience as a result of AptX low latency. Using either input optical or auxiliary audio available makes your Soundgear compatible with most TVs.
  • Comfort-fit design
    An ergonomic shape that rests gently on your shoulders and soft touch materials that fit all sizes combine to create an unbelievably comfortable audio experience.
  • Intuitive controls
    Easily take control of your music or calls without taking off the Soundgear.
  • Seamlessly switch between devices
    Allows you to effortlessly switch from one Bluetooth device to the other. You can simply switch from a video on your tablet to a call on your mobile phone, so that you'll never miss a call.
JBL SoundGear BTA - speaker - for portable use - wireless
Speaker - for portable use
2 microphones
Hands-Free Function
Enclosure Colour
Speaker System
Speaker Type
Active
Nominal Output Power
6 Watt
Frequency Response
100 - 20000 Hz
Nominal Impedance
32 Ohm
Output Level (1m)
111 dB
Sensitivity
96 dB
Amplifier
Integrated
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Recommended Placing
Wearable, on shoulders
Speaker System Details
Speaker Details
Speaker - 2 x 3 Watt - 100 - 20000 Hz - 32 Ohm - active
Driver Details
Speaker: 4 x full-range driver - 1.22"
Bluetooth audio transmitter, charging cable
Rechargeable - lithium polymer
800 mAh
Run Time (Up To)
6 hours
Recharge Time
2 hours
350 g
Limited warranty - 1 year
Brand: JBL
Price Range Ex VAT: 150 - 300
