JBL Live 650BTNC Wireless Over-Ear Noise-Cancelling Headphones
Quicklinx: F796WS00 Mfr#: JBLLIVE650BTNCBLK
In your world, music is essential, so slip on a pair of JBL LIVE 650BTNC wireless over-ear noise-canceling headphones and elevate your day. Equipped with powerful 40mm drivers, JBL LIVE650BTNC headphones deliver JBL Signature Sound punctuated with enhanced bass so every track on every playlist pops. And when the music is the only thing that matters, the active Noise-Canceling technology allows you to block-out ambient sounds so nothing disturbs your groove. Need some help getting through the day? Easily access the Google Assistant or Amazon Alexa with a tap on the ear cup and play your favorite playlist, text your friend or check the weather and much more, without glancing at your phone. But that's not all. With a cool, lightweight and comfortable design, you'll enjoy up to 30 hours (20 hours with BT + ANC) of music streaming with 2 hours of recharging time, multi-point connection capabilities and a convenient detachable cable with remote/mic, that lets you play on even when the battery goes off. Rock out uninterrupted with the JBL LIVE650BTNC headphones.
  • Hands-free calls
    Stay in touch with your world by managing calls with the buttons on the ear-cup. When the battery is flat, just plug-in the audio cable and continue listening and chatting.
  • Multi-point connexion
    Allows you to effortlessly switch from one Bluetooth device to another. You can simply switch from a video on your tablet to a call on your mobile phone, so that you'll never miss a call.
  • Comfort-fit fabric headband
    Shaped around your head with a fitting fabric headband and soft ear cushions, the LIVE650BTNC are super comfy.
JBL LIVE 650BTNC - headphones with mic
Headphones - Bluetooth - wireless - 3.5 mm jack
Recommended Use
Portable electronics
Headphones Form Factor
Full size
Foldable
Wireless
Wireless Technology
Bluetooth
Radio Frequency Range
2.402 - 2.480GHz
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Stereo
Sound Effects
Signature Sound
Audio Specifications
Frequency Response 16 - 20000 Hz - Sensitivity 100 dB
Impedance
32 Ohm
Active Noise Canceling
Controls
Voice assistant
Intelligent Assistant
Siri, Google Assistant, Alexa
249 g
Earpad Material
Polyurethane leather
Recommended Use
Audio Output
Full size
Foldable
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Sound Effects
Signature Sound
Frequency Response
16 - 20000 Hz
Sensitivity
100 dB
Impedance
32 Ohm
Diaphragm
40 mm
TalkThru technology
Microphone
Built-in
Remote Control
Controls
Voice assistant
Wireless Link
2.402 - 2.480GHz
Modulation Type
GFSK, 8-DPSK, DQPSK
Cable
Cable Length
1.2 m
Internet of Things (IoT)
Cable Details
Charging cable - detachable , Headphones cable - detachable - 1.2 m
Headphone battery rechargeable - lithium polymer
700 mAh
Run Time (Up To)
30 hour(s)
Recharge Time
2 hour(s)
