JBL Link 300 Voice-Activated Speaker - Black
Quicklinx: DXP0WS00 Mfr#: JBLLINK300BLKUK
Select:
The JBL Link 300 is a voice-activated speaker with Wi-Fi and Bluetooth enabled that delivers incredible room-filling sound from a compact design. It has the Google Assistant built-in. It's your own personal Google. Always ready to help. You can ask it questions. And tell it to do things. The more you use it, the more useful it gets. Just start with "Ok Google" - a simple voice request triggers your JBL Link 300 to play music, podcasts or radio from services like Google Play Music, Spotify, Pandora and more. To amplify your party, speakers with Chromecast built-in can be grouped together to enjoy the same song in every room.
  • Get help from your Google Assistant
    JBL Link 300 has the Google Assistant built-in. It is your own personal Google. Always ready to help.
  • Hands-free voice control
    Far-field voice recognition allows for easy hands-free operation. Ask questions across the room and the JBL Link 300 will respond.
  • Simple setup with the Google Home app on iOS and Android
    With the free Google Home app on iOS and Android, you can easily setup and manage your JBL Link 300.
  • Chromecast built-in
    Lets you instantly stream your favorite music, radio, or podcast from your mobile device to your speakers.
  • 24 bit/96kHz high quality sound, powered by the cloud
    Chromecast streams directly from the cloud, so you get the highest sound quality. Enjoy crystal clear sound exactly the way the artist intended.
  • Multi-room playback across speakers that have Chromecast built-in
    Easily set up your system and control multi-room playback with the Google Home app. A step by step guide allows you to quickly start streaming your music.
  • 2.4/5GHz Wi-Fi connection network support
    Support both 2.4GHz and 5 GHz Wi-Fi connection, resulting in a faster, robust and more stable wireless connection.
  • Wireless Bluetooth streaming
    Wirelessly stream high-quality sound from your smartphone or tablet.
  • Room-filling sound
    A compact design equipped with high performance JBL transducers to deliver incredible room filling sound.
JBL LINK 300 - smart speaker
Smart speaker
United Kingdom
Speaker Type
2-way - active
Nominal Output Power
50 Watt
Frequency Response
55 - 22000 Hz
Bluetooth, Wi-Fi
Platform
Google Home
Intelligent Assistant
Google Assistant - direct
Streaming Services
Pandora, Spotify, Google Play Music, Chromecast
Audio Formats
WAV, MP3, FLAC, AAC-LC, LPCM, HE-AAC, OPUS, Vorbis
Speaker Details
Speaker - stereo x 2 - 25 Watt - 55 - 22000 Hz - 2-way - active
23.6 cm x 15.4 cm x 13.4 cm
1.7 kg
Smart speaker
Hands-Free Function
Microphone
Enclosure Colour
United Kingdom
Speaker System
Speaker Type
2-way - active
50 Watt
Frequency Response
55 - 22000 Hz
Signal-To-Noise Ratio
80 dB
Maximum Sampling Rate Supported
96 kHz
Multiroom
Amplifier
Integrated
Bluetooth 4.2, IEEE 802.11b/g/n/ac
Internet Streaming Services
Audio Formats
Controls
Voice control
Internet of Things (IoT)
Platform
Google Home
Communications Type
Cloud
Intelligent Assistant Compatible
Google Assistant
Voice Control
Direct
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 25 Watt - 55 - 22000 Hz CFR - 2-way - active
Driver Details
Woofer driver - 3.5" , Tweeter driver - 0.79"
Power adapter, charging cable
Power Source
AC power adapter
23.6 cm
15.4 cm
13.4 cm
1.7 kg
