Bluetooth connectivity
Allows you to wirelessly stream music through any Bluetooth enabled device. -
Rechargeable battery
Features a rechargeable battery for convenient portability and extended playback time. -
Built-in microphone
The built-in microphone allows you to answer calls without skipping a beat.
- JBL Go - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Pink
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable
- 8.27 cm x 3.08 cm x 6.83 cm
- Product Type
- Hands-Free Function
- Enclosure Colour
- Pink
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Controls
- Power on/off, volume, call answer
- Additional Features
- Noise filter, voice echo cancellation, integrated strap hook
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Power Source
- Battery
- Options
- USB charging
- Rechargeable
- Run Time (Up To)
- 5 hour(s)
- 8.27 cm
- 3.08 cm
- 6.83 cm
