JBL Go portable speaker - Grey
Quicklinx: DBDVWS00 Mfr#: JBLGOGRAY
Colours:
JBL Go is a full-featured, great-sounding, great-value portable speaker.
  • Bluetooth connectivity
    Allows you to wirelessly stream music through any Bluetooth enabled device.
  • Rechargeable battery
    Features a rechargeable battery for convenient portability and extended playback time.
  • Built-in microphone
    The built-in microphone allows you to answer calls without skipping a beat.
JBL Go - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Amplifier
Integrated
Bluetooth
Grey
Power Options
USB charging
Speaker battery rechargeable
8.27 cm x 3.08 cm x 6.83 cm
Hands-Free Function
Enclosure Colour
Grey
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth
Controls
Power on/off, volume, call answer
Additional Features
Noise filter, voice echo cancellation, integrated strap hook
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Power Source
Options
USB charging
Rechargeable
Run Time (Up To)
5 hour(s)
8.27 cm
3.08 cm
6.83 cm
