JBL Go 2 Bluetooth Speaker - Grey
Quicklinx: DVZPWS00 Mfr#: JBLGO2GRY
Colours:
The JBL GO 2 is a portable, compact Bluetooth speaker with next-generation audio quality and a bolder design. This next generation of the fan-favorite JBL GO speaker packs a punch, with even more audio output in the same compact palm-sized design. With long-lasting playtime and JBL Signature Sound, coupled with increased audio quality and performance, the JBL GO 2 is the perfect speaker for consumers looking for an easy-to-use, on-the-go music experience.
Making a splash with its waterproof IPX7 design, the JBL GO 2 gives music lovers everywhere the opportunity to bring their speaker poolside, to the beach, or on a porch or patio. For consumers looking for more versatility in a portable speaker, the JBL GO 2 comes equipped with an echo and noise canceling speakerphone. Users can make crystal-clear calls by simply connecting their smartphone via Bluetooth.
  • Bluetooth connectivity
    Allows you to wirelessly stream music through any Bluetooth enabled device.
  • Rechargeable battery
    Features a rechargeable battery for convenient portability and extended playback time.
  • Built-in microphone
    The built-in microphone allows you to answer calls without skipping a beat.
JBL Go 2 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof
Speaker Type
Active
Continuous Power
3 Watt
Frequency Response
180 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - mono - 3 Watt - 180 - 20000 Hz - active
Misty grey
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
8.6 cm x 3.16 cm x 7.12 cm
184 g
1-year warranty
Hands-Free Function
Microphone
Protection
Waterproof
Enclosure Colour
Misty grey
Speaker System
Speaker Type
Active
Continuous Power
3 Watt
Frequency Response
180 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Bluetooth 4.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Speaker System Details
Speaker Details
Speaker - mono - 3 Watt - 180 - 20000 Hz CFR - active
Driver Details
Speaker: full-range driver
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Micro-USB charging cable
IPX7
Max Depth of Water Resistance
1 m
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
730 mAh
Run Time (Up To)
5 hour(s)
Recharge Time
2.5 hour(s)
8.6 cm
3.16 cm
7.12 cm
184 g
Limited warranty - parts and labour - 1 year
