JBL Clip 3 Carabiner Bluetooth Speaker - Red
Quicklinx: DW0MWS00 Mfr#: JBLCLIP3RED
Speaker Type: Speaker
Connection: Wireless
£33.12 ex VAT
£39.74 inc VAT
Like no other, the JBL Clip 3 is a unique ultra-portable, ultra-rugged and waterproof Bluetooth speaker that is small in size but with surprisingly big sound. The upgraded durable and fully integrated carabiner clips to your clothes, belt loop or backpack, making the Clip 3 your outdoor companion on every adventure.
  • Ultra-compact high-performance audio
    The JBL Clip is small in stature but big in sound. With high performance compact driver the Clip can deliver your music as loud and clear as you needed, where ever you take it.
  • Stream Bluetooth music and calls wirelessly and accurately
    Stream your music or make a phone call - wirelessly - with the Clips built in Bluetooth. Its easy to set up and you can stream wirelessly from any tablet or smartphone.
  • Ready-to-wear audio with integrated carabiner
    With a rugged carabineer designed to hook onto your clothes, your backpack, or messenger bag, the JBL Clip keeps on-the-go pace with however fast you're going. The rugged make of the Clip also lends itself to resisting wear-and-tear while moving quickly: the portable speaker's protected by durable material with double injection housing that allows it to land safely and softly - even when it gets tossed into your backpack a little too roughly.
JBL Clip 3 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof
Speaker Type
Active
Nominal Output Power
3.3 Watt
Frequency Response
120 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - mono - 3.3 Watt - 120 - 20000 Hz - active
Red
Speaker battery rechargeable - Lithium Ion
9.7 cm x 4.6 cm x 13.7 cm
220 g
1-year warranty
Hands-Free Function
Protection
Waterproof
Enclosure Colour
Red
Design Features
Built-in carabiner clip
Speaker System
Speaker Type
Active
3.3 Watt
Frequency Response
120 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Bluetooth 4.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Controls
Power on/off, play/pause
Speaker System Details
Speaker Details
Speaker - mono - 3.3 Watt - 120 - 20000 Hz CFR - active
Driver Details
Speaker: full-range driver
Micro-USB charging cable
IPX7
Max Depth of Water Resistance
1 m
Rechargeable - Lithium Ion
Capacity (Ah)
1000 mAh
Run Time (Up To)
10 hour(s)
Recharge Time
3 hour(s)
9.7 cm
4.6 cm
13.7 cm
220 g
Limited warranty - parts and labour - 1 year
Brand: JBL
Price Range Ex VAT: 0 - 50
