JBL Clip 2 Portable Bluetooth speaker - Red
Quicklinx: DBF2WS00 Mfr#: JBLCLIP2REDEU
Colours:
The JBL Clip 2 is a light, rugged and powerful portable speaker. Completely waterproof, the JBL Clip 2 provides many hours of playtime, allowing you to take your music wherever you go, be it land or water. Stream music wirelessly via Bluetooth, or plug it into any smartphone or tablet. You can also wirelessly connect two Clip 2 speakers together to enjoy amplified sound. Use the speakerphone to make clear, noise and echo free phone calls. The JBL Clip 2 is covered with durable waterproof fabric, and earns its name with its carabiner, clipping to your clothes or backpack to take on any adventure.
  • Wireless Bluetooth streaming
    Wirelessly stream high-quality sound from your smartphone or tablet.
  • Rechargeable battery
    Built-in rechargeable Li-ion battery supports many hours of playtime.
  • Speakerphone
    Take crystal clear calls from your speaker with a touch of a button - thanks to the noise and echo free speakerphone.
  • Built-in carabiner
    Hook the Clip 2 onto anything you see fit and take it on all your adventures.
  • IPX7 waterproof
    No more worrying about rain or spills, you can even submerge the Clip 2 in water.
  • Wireless daisy chain
    You can wirelessly connect two Clip 2 speakers together to enjoy amplified sound.
JBL Clip 2 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof
Speaker Type
Active
Continuous Power
3 Watt
Frequency Response
120 - 20000 Hz
Amplifier
Integrated
Bluetooth
Red
Image Colour Disclaimer
The displayed product image may be a different colour
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
9.4 cm x 4.2 cm x 14.1 cm
184 g
Hands-Free Function
Microphone
Protection
Waterproof
Enclosure Colour
Red
Enclosure Material
Fabric, rubber
Design Features
Built-in carabiner clip
Speaker System
Speaker Type
Active
Continuous Power
3 Watt
Frequency Response
120 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Bluetooth 4.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Controls
Power on/off, call answer
Speaker System Details
Driver Details
Speaker: full-range driver
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Micro-USB cable
IPX7
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
730 mAh
Run Time (Up To)
8 hour(s)
Recharge Time
2.5 hour(s)
9.4 cm
4.2 cm
14.1 cm
184 g
