The loudest JBL boombox ever
Turn it up. Way up. Get the loudest, most massive JBL Signature Pro Sound on JBL most powerful portable speaker, the JBL Boombox 2. -
Monstrous bass you can feel
Dance parties thrive on bass, so let your friends feel it. JBL Boombox 2 pumps out powerful deep bass just like your favourite JBL powered club. -
Keep the party going with 24 hours of playtime
The fun doesn't have to stop. Packed with an incredible 24 hours of battery life, JBL Boombox 2 lets you party all day and all night. -
Make a splash with IPX7 waterproof design
Bring your speakers anywhere. Pool party? Perfect. Sudden cloudburst? Covered. Bash on the beach? JBL Boombox 2 is IPX7 waterproof up to three-feet deep for fearless outdoor entertainment. -
Strong, bold design
Sleek. Bold. Powerful. With its iconic grip handle and stylish side flares, JBL Boombox 2 will turn heads wherever you take it. -
Crank up the fun with PartyBoost
PartyBoost allows you to link multiple JBL PartyBoost-compatible speakers to pump up the party. -
Power up with the built-in powerbank
Don't put the party on pause. A built-in powerbank lets you charge your devices without taking a break from the tunes.
- JBL Boombox 2 - boombox speaker - for portable use - wireless
- Product Type
- Boombox speaker - for portable use
- Protection
- Splashproof
- Speaker Type
- 2-way - active
- Continuous Power
- 80 Watt
- Frequency Response
- 50 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - 40 Watt - 50 - 20000 Hz - 2-way - active
- Black
- Power Options
- USB charging (powerbank function)
- Battery
- Speaker battery rechargeable - lithium polymer
- 48.5 cm x 25.7 cm x 20.1 cm
- 5.9 kg
- Product Type
- PartyBoost
- Protection
- Splashproof
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- 2-way - active
- Continuous Power
- 80 Watt
- 50 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Bluetooth 5.1
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 40 Watt - 50 - 20000 Hz CFR - 2-way - active
- Driver Details
- Speaker: 2 x woofer driver - 4" , Speaker: 2 x tweeter driver - 0.79"
- Connector Type
- DC power output (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Power adapter
- IPX7
- Power Source
- AC power adapter, battery
- Options
- Rechargeable - lithium polymer
- Capacity (Ah)
- 10000 mAh
- Run Time (Up To)
- 24 hours
- Recharge Time
- 6.5 hours
- 48.5 cm
- 25.7 cm
- 20.1 cm
- 5.9 kg
