The JBL Bar 5.1 transforms from a soundbar into a true wireless 5.1 home theater system for an epic movie and music-listening experience. The soundbar features two detachable battery-powered wireless surround speakers with long hours of playtime, total system power, a wireless subwoofer, HDMI inputs to connect 4K devices and Bluetooth. With Dolby Digital, Dolby Pro Logic II and DTS, your movies, music and video games will never sound more incredible. The soundbar features JBL SoundShift, which allows you to instantly switch between the sound from your TV and the Bluetooth sound from your mobile phone or tablet. The soundbar is programmed to respond to your TV remote, so you can control everything with your existing TV remote control. The JBL Bar 5.1 redefines the soundbar experience.
JBL 5.1 surround sound with high power
Ensures a high-quality audio performance for your movies and music. -
Detachable, battery-powered wireless surround speakers
Enjoy true wireless surround sound in cinematic 5.1 with long hours of playing time. -
Thrilling bass from a wireless subwoofer
Enjoy rich and thrilling bass with the convenience of flexible placement without the hassle of wires.
- JBL Bar 5.1 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 5.1-channel
- System Components
- 2 speakers, subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 510 Watt
- Frequency Response
- 35 - 20000 Hz
- Bluetooth
- Speaker System Details
- 1 x sound bar , 1 x subwoofer , 2 x surround channel speaker
- Built-in Decoders
- Dolby Pro Logic II, Dolby Digital, DTS decoder
- 1-year warranty
- Product Type
- Design Features
- Detachable wireless battery-powered rear channel speakers
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 510 Watt
- 35 - 20000 Hz
- Max Output Level (Max SPL)
- 104 dB
- Audio Return Channel (ARC) Capability
- Bluetooth 4.2
- Video Pass-Through
- 2160 (4K)
- Built-in Decoders
- Speakers Included
- 1 x sound bar - wall-mountable , 1 x subwoofer - wireless , 2 x surround channel speaker - wireless
- Driver Details
- Sound bar: 6 x mid-range driver - 2.25" , Sound bar: 3 x tweeter driver - 1.25"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 10"
- Connector Type
- 3 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB
- Included Accessories
- Audio cable, digital audio cable (optical), remote control, wall mounting kit, HDMI cable, batteries, calibration microphone
- Dimensions (WxDxH) / Weight Details
- Sound bar: 114.8 cm x 9.3 cm x 5.8 cm / 3.9 kg , Subwoofer: 44 cm x 30.5 cm x 30.5 cm / 13 kg , Surround channel speaker: 16.2 cm x 9.3 cm x 5.9 cm / 600 g
- Limited warranty - 1 year
