JBL 3.1-Channel 4K Ultra HD Soundbar with Wireless Subwoofer
Quicklinx: DBFCWS00 Mfr#: JBLBAR31BLKEP
JBL's soundbar series fills any room with theater-quality sound to elevate the enjoyment of TV, movies, music and video games. In addition to featuring JBL Signature Sound and Dolby Digital decoding, the BAR series comes equipped with additional speakers to further enhance the sound performance. Exceptional bass ensures viewers won't miss a single beat or blast, whether listening to music or indulging in the latest Hollywood thriller.
Engineered to make entertainment simpler, the BAR series is easy to set up and has multiple convenient connections, including HDMI and HDMI ARC inputs as well as Optical and AUX wired connections. The 3.1 model comes with multiple 4K HDMI pass-through inputs to connect additional devices like Blu-Ray players, game consoles and more. For increased ease of use, the soundbar is programmed to respond to the TV remote, eliminating the need for multiple controllers. For those who love the second screen experience, the JBL BAR series also comes equipped with JBL SoundShift technology, allowing users to instantly swap audio sources.
JBL Bar 3.1 - sound bar system - for TV - wireless
Sound bar system - for TV - 3.1-channel
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
450 Watt
Frequency Response
35 - 20000 Hz
Bluetooth
Speaker System Details
1 x sound bar , 1 x subwoofer
Built-in Decoders
Dolby Digital
Sound Effects
JBL Surround Sound
1-year warranty
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
450 Watt
Frequency Response
35 - 20000 Hz
Max Output Level (Max SPL)
103 dB
Sound Effects
JBL Surround Sound
Audio Return Channel (ARC) Capability
Bluetooth 4.2
Built-in Decoders
Dolby Digital
Speakers Included
1 x sound bar - wall-mountable , 1 x subwoofer - wireless
Driver Details
Sound bar: 6 x mid-range driver - 2.25" , Sound bar: 3 x tweeter driver - 1.25"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 10"
Connector Type
3 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB
Audio cable, remote control, wall mounting kit, HDMI cable, batteries
Dimensions (WxDxH) / Weight Details
Sound bar: 101.8 cm x 7.8 cm x 5.8 cm / 2.3 kg , Subwoofer: 44 cm x 30.5 cm x 30.5 cm / 12.1 kg
Limited warranty - 1 year
