JBL's soundbar series fills any room with theater-quality sound to elevate the enjoyment of TV, movies, music and video games. In addition to featuring JBL Signature Sound and Dolby Digital decoding, the BAR series comes equipped with additional speakers to further enhance the sound performance. Exceptional bass ensures viewers won't miss a single beat or blast, whether listening to music or indulging in the latest Hollywood thriller.
Engineered to make entertainment simpler, the BAR series is easy to set up and has multiple convenient connections, including HDMI and HDMI ARC inputs as well as Optical and AUX wired connections. The 3.1 model comes with multiple 4K HDMI pass-through inputs to connect additional devices like Blu-Ray players, game consoles and more. For increased ease of use, the soundbar is programmed to respond to the TV remote, eliminating the need for multiple controllers. For those who love the second screen experience, the JBL BAR series also comes equipped with JBL SoundShift technology, allowing users to instantly swap audio sources.
- JBL Bar 3.1 - sound bar system - wireless
- Product Type
- Sound bar system - 3.1-channel
Speaker System
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 450 Watt
- Frequency Response
- 35 - 20000 Hz
- Output Level (1m)
- 103 dB
- Sound Effects
- JBL Surround Sound
- Bluetooth 4.2
- Built-in Decoders
- Dolby Digital
Speaker System Details
- Speakers Included
- 1 x sound bar - wall-mountable , 1 x subwoofer - wireless
- Driver Details
- Sound bar: 6 x mid-range driver - 2.25" , Sound bar: 3 x tweeter driver - 1.25"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 10"
- Connector Type
- 3 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB
- Included Accessories
- Audio cable, remote control, wall mounting kit, HDMI cable, batteries
- Dimensions (WxDxH) / Weight Details
- Sound bar: 101.8 cm x 7.8 cm x 5.8 cm / 2.3 kg , Subwoofer: 44 cm x 30.5 cm x 30.5 cm / 12.1 kg
