Enjoy JBL sound with 300W of power
The 300W of power output ensures great audio performance for your movies and music.
JBL Surround Sound makes movies come alive
Bring movies to life with JBL Surround Sound, without the hassle of any additional wires or speakers.
Rich and deep bass from a 6.5" (165mm) wireless subwoofer
Enjoy rich and deep bass as well as the convenience of flexible placement without the hassle of wires.
- Wireless music streaming with Bluetooth: Stream all your music wirelessly from any mobile device.
- Connect your devices with HDMI IN/ 1 HDMI out (ARC): Connect your devices and simplify your home entertainment setup.
- Works with your TV remote control: This JBL soundbar is designed to work with many of today's top TV remote controls, so you can use your existing TV remote control for both TV and soundbar.
The 300W of power output ensures great audio performance for your movies and music. -
Bring movies to life with JBL Surround Sound, without the hassle of any additional wires or speakers. -
Rich and deep bass from a 6.5" wireless subwoofer
Enjoy rich and deep bass as well as the convenience of flexible placement without the hassle of wires. -
Stream all your music wirelessly from any mobile device. -
Connect your devices with HDMI in/1 HDMI out
Connect your devices and simplify your home entertainment setup. -
- JBL Bar 2.1 - sound bar system - wireless
- Product Type
- Sound bar system - 2.1-channel
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 300 Watt
- Frequency Response
- 40 - 20000 Hz
- Bluetooth
- Speaker System Details
- 1 x sound bar , 1 x subwoofer
- Black-EMEA
- Built-in Decoders
- Dolby Digital
- Sound Effects
- JBL Surround Sound
- Product Type
- Enclosure Colour
- Black-EMEA
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 300 Watt
- 40 - 20000 Hz
- Max Output Level (Max SPL)
- 99 dB
- Sound Effects
- Bluetooth 4.2
- Recommended Placing
- Wall-mountable
- Built-in Decoders
- Dolby Digital
- Speakers Included
- 1 x sound bar , 1 x subwoofer - wireless
- Driver Details
- Sound bar: 4 x mid-range driver - 2.25" , Sound bar: 2 x tweeter driver - 1.25"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 6.5"
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB
- Included Accessories
- Audio cable, remote control, wall mounting kit, batteries, audio (optical) cable
- HDCP 1.4
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Sound bar: 96.5 cm x 6.8 cm x 5.8 cm / 1.9 kg , Subwoofer: 22.5 cm x 22.5 cm x 37 cm / 5.2 kg
