Amplify your music experience with high-fidelity speakers and active noise cancellation.
All of the music None of the noise
Take your music experience to another level. Jabra Vega comes with custom-designed high-fidelity speakers, sound and powerful active noise cancellation that lets you hear your music in pure sound without distraction. -
Your on-the-go companion
Block out up to 99% of the noise around you, creating your own personal space on the go. You can tune in and out of your surroundings by simply tapping the Eavesdrop button. The active noise cancellation conveniently powers off when folded flat. In-line controls allow you to manage calls and music and keep your phone in your pocket. -
Unparallelled build quality
Jabra Vega is crafted with premium materials for ultimate durability and superior comfort. With up to 35 hours of ANC and music, you don't need to worry about running out of power. -
Highest audio fidelity
Custom-designed speakers – amplify your music in the highest audio fidelity without distortion. -
RICH DOLBY® SOUND
Experience your music and YouTube content in full-spectrum Dolby sound via the exclusive Jabra Sound app . -
ALL OF THE MUSICNONE OF THE NOISE
HIGHEST AUDIO FIDELITY
UNPARALLELLED BUILD QUALITY
YOUR ON-THE-GO COMPANION
- Jabra Vega - headphones with mic
- Product Type
- Headphones - wired - 3.5 mm jack
- Recommended Use
- Home audio, portable electronics, computer
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 108 dB
- Impedance
- 32 Ohm
- Max Input Power
- 90 mW
- Active Noise Canceling
- Microphone
- On-cable
- Controls
- Answer/end, play/pause
- 1-year warranty
- Product Type
- 15.37 cm
- 18.35 cm
- 278 g
- Body Material
- Aluminium, polyurethane, silicone, zinc, TPE, PC/ABS
- Earpad Material
- Foam
- Recommended Use
Audio Output
- Full size
- Foldable
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Max Input Power
- 90 mW
- Total Harmonic Distortion (THD)
- 1.0%
- Sensitivity
- 108 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
Microphone
- On-cable
- Sensitivity
- -42 dB
- 100 - 8000 Hz
- Audio Input Details
- Omni-directional
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
- Detachable Cable
- Software Included
- Jabra Sound
- Included Accessories
- AAA battery, in-flight plug adapter, protective pouch
- Cable Details
- Headphones cable - 1.2 m
- PCT, EMC, REACH, RoHS 2011/65/EU, EN 55024:2010, EN 55022:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- Battery
- 1 x battery - AAA type Alkaline
- Included Qty
- 1
- Run Time (Up To)
- 35 hour(s)
- Limited warranty - 1 year
