Jabra UC Voice 750 Mono UC Wired Headset - Grey
Reduced Price - Whilst Stocks Last!
Quicklinx: 7NLJWS00 Mfr#: 7593-829-409
The Jabra UC VOICE 750 is a corded headset designed specifically for Unified Communications deployments. The headset is ideal for the office professional who often uses UC voice applications. It features a lightweight design for maximum comfort all-day long. The Jabra UC VOICE 750 is made for design-conscious professionals who value a unique design.
  • Crystal-clear sound
    The headset features superior sound clarity and HD Voice for softphone calls, conference calls, live presentations and other multimedia applications. The microphone includes a noise-reduction feature, ensuring that the recipient cannot hear background noise from the speaker's surroundings. This makes the headset suitable for use in louder office environments.
  • Easy to deploy and operate
    The Jabra UC Voice 750 headset is certified and optimised with all leading Unified Communications platforms. Simply connect the headset to the computer and it is ready to use. Your IT department won't struggle with compatibility issues or time-consuming installations. The intuitive call control unit attached to the cord allows for fast user adoption.
  • Flexible boom-arm tip for optimal positioning
    The Jabra UC Voice 750 headset has a flexible boom-arm tip to ensure the ideal microphone placement.
  • Two new colour models
    The Jabra UC Voice 750 headset is made for design-conscious professionals who value a unique design. The headset has a thin headband and comes in both light and dark colours.
  • HiFi Sound
    Immerse yourself in music with hi-fi sound. Listen to flawless music reproduction across the entire audible frequency range.
  • UC Plug-And-Play
    Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
Jabra UC Voice 750 Mono Dark - headset
Headset - wired
Recommended Use
Phone, conference - communication
Dark
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Headset - wired
Dark
Recommended Use
Headphones
On-ear
Wired
Sound Output Mode
Mono
In-Cord Volume Control
Microphone
Boom
Remote Control
Headset remote control
Controls
Connector Type
Headset (4 PIN USB Type A)
Headset cable
Travel bag
Plug and Play
7NLJ Jabra USB-A to USB-C Adapter In Stock £7.73
Resources
The following resources are available for the Jabra UC Voice 750 Mono UC Wired Headset - Grey
