Jabra UC Voice 150 Mono Wired Headset
Quicklinx: 7NKQWS00 Mfr#: 1593-829-209
The Jabra UC Voice 150 is a corded headset designed specifically for Unified Communication deployments. It is a perfect for light use by office professionals in both small and large office environments.
  • Certified and optimised for UC
    The Jabra UC Voice 150 is a simple, one-step solution to getting users engaged with UC voice solutions. It is certified and optimised for use with all major UC platforms, is USB plug-and-play ready and features simple call control through the in-line switch on the cord. All this equals stress-free deployment and fast user uptake.
  • Crystal-clear sound
    The Jabra UC Voice 150 has sound quality features you wouldn't normally expect in an entry level headset. HD Voice delivers crystal clear wideband sound for voice calls and multimedia, while the noise-cancelling microphone filters out ambient noise.
  • Flexible boom-arm tip for optimal positioning
    The Jabra UC Voice 150 has a flexible boom tip to ensure that the user can properly position the microphone for the best possible voice clarity.
  • Maximum impact, minimum cost
    The Jabra UC Voice 150 series is a cost-effective, quality headset from a brand you trust for those users just getting into UC voice and multimedia.
  • HiFi Sound
    Immerse yourself in music with hi-fi sound. Listen to flawless music reproduction across the entire audible frequency range.
  • UC Plug-And-Play
    Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
Jabra UC Voice 150 Mono - headset
Headset - wired
Recommended Use
Conference - communication
Grey
Headphones Form Factor
On-ear monaural
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Headset - wired
Grey
Recommended Use
Audio Output
On-ear monaural
Wired
Sound Output Mode
Mono
In-Cord Volume Control
Microphone
Boom
Remote Control
Headset remote control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable Details
Headset cable
Plug and Play
