Stay in touch simply and hear every conversation clearly, with the easy-to-use Jabra TALK Bluetooth headset. Every time you make a call, you'll hear it in HD sound quality - for the ultimate in crisp, clear sound without confusion or disruptions. That means you can stay focused on the call and keep talking while you multitask.
Crystal clear sound
Every call will come through in HD quality*, giving you crisp, clear sound without disruptions. The Jabra Talk also uses digital signal processing and a noise filtering mic to make sure the other party hears only your voice. *Device dependent. -
Connect 2 devices at the same time
>With the Multiuse feature, you can easily connect to two devices at the same time. When one of them rings, the Jabra Talk will automatically stream the right call when you answer. If a new call comes through on the other phone, you'll get an alert and the option to pick it up. -
Easy to use
Jabra Talk is designed for new Bluetooth users and comes with an intuitive on/off slider button. The volume automatically adjusts to adapt to your environment. You also get spoken updates when the Jabra Talk is connected or when the battery is running low.
- Jabra TALK - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear - over-the-ear mount - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0 EDR
- Sound Output Mode
- Mono
- Impedance
- 32 Ohm
- Microphone
- Built-in
- Microphone Operation Mode
- Mono
- Controls
- Volume, on/off, answer/end
- 1-year warranty
- Product Type
- 1.66 cm
- 5.35 cm
- 2.42 cm
- 9.5 g
- Body Material
- PC/ABS
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Mono
- Impedance
- 32 Ohm
Microphone
- Mono
- Frequency Response
- 300 - 3000 Hz
- Audio Input Details
- Omni-directional
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Included Accessories
- 2 earhooks, 2 gel ear tips
- GOST, IC, FCC, RoHS, REACH
- Power Device
- Power adapter - external
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 6 hour(s)
- Standby Time
- 192 hours
- Limited warranty - 1 year
