Jabra Talk
Jabra Talk
Quicklinx: 9ZC9WS00 Mfr#: 100-92200000-60
Stay in touch simply and hear every conversation clearly, with the easy-to-use Jabra TALK Bluetooth headset. Every time you make a call, you'll hear it in HD sound quality - for the ultimate in crisp, clear sound without confusion or disruptions. That means you can stay focused on the call and keep talking while you multitask.
  • Crystal clear sound
    Every call will come through in HD quality*, giving you crisp, clear sound without disruptions. The Jabra Talk also uses digital signal processing and a noise filtering mic to make sure the other party hears only your voice. *Device dependent.
  • Connect 2 devices at the same time
    >With the Multiuse feature, you can easily connect to two devices at the same time. When one of them rings, the Jabra Talk will automatically stream the right call when you answer. If a new call comes through on the other phone, you'll get an alert and the option to pick it up.
  • Easy to use
    Jabra Talk is designed for new Bluetooth users and comes with an intuitive on/off slider button. The volume automatically adjusts to adapt to your environment. You also get spoken updates when the Jabra Talk is connected or when the battery is running low.
Jabra TALK - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics
Headphones Form Factor
In-ear - over-the-ear mount - monaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0 EDR
Sound Output Mode
Mono
Impedance
32 Ohm
Microphone
Built-in
Microphone Operation Mode
Mono
Controls
Volume, on/off, answer/end
1-year warranty
1.66 cm
5.35 cm
2.42 cm
9.5 g
Body Material
PC/ABS
Recommended Use
Max Operating Distance
10 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Impedance
32 Ohm
Microphone
Mono
Frequency Response
300 - 3000 Hz
Audio Input Details
Omni-directional
Remote Control
Controls
Wireless Link
Transmission Range
10 m
2 earhooks, 2 gel ear tips
GOST, IC, FCC, RoHS, REACH
Power adapter - external
Headset battery rechargeable
Run Time (Up To)
6 hour(s)
Standby Time
192 hours
Limited warranty - 1 year
