The Jabra TAG is the iconic wireless pendant with FM radio that allows you to control your music and phone calls anywhere you want.
Skip tracks, take calls, wirelessly
The Jabra TAG is the iconic Bluetooth stereo headset with FM radio that allows you to control your music and phone calls anywhere you want. -
Built-in FM radio and precision sound
Jabra TAG gives you high quality stereo sound when you're on the move with noise isolating ear buds and built in FM radio. Now you can listen to your favorite tunes from your phone or your favorite radio station while you're on the go. Even when you aren't connected to a device, Jabra TAG can still provide the entertainment - it's quick and easy to tune in to the stations you want. -
Swap between music and conversation
With Jabra TAG, you can keep your phone safe in your pocket while you play music, change tracks, crank up the volume and take or make calls - all wirelessly. An automatic switch makes it easy to control your music and when a call comes in, the device alerts you. With one tap you can take the call and when it ends you can go back to enjoying your tracks. It even comes with up to 7 hours of music time and 8 hours of talk time, giving you all the sound you need when you're on the move. -
Wear it your way
The way you wear your Jabra TAG is up to you - you can hang it around your neck like a fashionable tag or clip it on. Either way, it's unique design means you're never out of touch - with your music or your friends.
- Jabra TAG - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Additional Functions
- FM radio
- Black, silver
- Headphones Form Factor
- In-ear binaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Sound Output Mode
- Stereo
- Impedance
- 32 Ohm
- Microphone Operation Mode
- Mono
- Controls
- Volume
- 1-year warranty
- Product Type
- FM radio
- 3.4 cm
- 0.8 cm
- 5.6 cm
- 30 g
- Black, silver
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- In-ear binaural
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Impedance
- 32 Ohm
Microphone
- Mono
- Sensitivity
- 14 dB
- Audio Input Details
- Omni-directional
Remote Control
- Remote control
- Supported Devices
- Digital player, mobile phone
- Controls
- Volume
Wireless Link
- Transmission Range
- 10 m
- Included Accessories
- Lanyard, clothing clip
- Power Device
- Power adapter - external
- Voltage Required
- AC 120/230 V (50 - 60 Hz)
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 8 hour(s)
- Standby Time
- 204 hours
- Limited warranty - 1 year
