Jabra Style Bluetooth Headset- White
Quicklinx: 9ZCZWS00 Mfr#: 100-99600001-60
It is straightforward headset with wireless freedom and all the sophistication for your personal style. Ease of use has been essential in the design of Jabra Style. There's only one button for most tasks, and the volume and background noise are taken care of without you having to lift a finger.
  • Stylish design
    You don't need to sacrifice style when multitasking is a must. Jabra Style is remarkably lightweight and has a stylish, brushed steel surface. It's designed to look sophisticated yet not too flashy.
  • Easy to use
    Ease of use has been essential in the design of Jabra Style. There's only one button for most tasks, and the volume and background noise are taken care of without you having to lift a finger. The headset will even give you spoken updates when it's connected or when the battery is running low.
  • All-day comfort
    The Jabra Style is made to be worn comfortably throughout the day. It has a transparent ear hook and ergonomically designed Eargels that you can exchange to find the perfect fit.
Jabra Style - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics
White
Headphones Form Factor
Ear-bud - over-the-ear mount - monaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Mono
Microphone
Built-in
2.41 cm
1.64 cm
6.69 cm
10 g
White
Recommended Use
Max Operating Distance
10 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Microphone
Audio Input Details
Omni-directional
Wireless Link
Transmission Range
10 m
Eartip
Power adapter - external
AC 100/230 V (50/60 Hz)
Headset battery rechargeable
Run Time (Up To)
6 hour(s)
Standby Time
168 hours
