For listening to music stored on your smartphone in the car, Jabra Streamer is the perfect solution. Jabra Streamer connects to your car stereo via a AUX and sets up a Bluetooth connection to your smartphone.
When you connect the Jabra Streamer to the in-car music system, you can stream music wirelessly from your smartphone and enjoy it in great stereo sound.
Mount the Jabra Streamer on the car's dashboard and leave your smartphone in your bag or pocket. Use the control panel to pause, play and skip tracks, switch between music and calls and activate and engage Siri or Google Now remotely on your smartphone.
Jabra Streamer is a true Plug and Play solution. When connected to your car stereo and paired to your smartphone, you're ready to stream music. And it automatically switches on and off with your car ignition, so you don't have to think about it.
Enjoy Music & Calls Wirelessly On Your Car Stereo
For listening to music stored on your smartphone in the car, Jabra Streamer is the perfect solution. Jabra Streamer connects to your car stereo via a 3.5mm AUX and sets up a Bluetooth® connection to your smartphone. -
Your Music In Great Sound
When you connect the Jabra Streamer to the in-car music system, you can stream music wirelessly from your smartphone and enjoy it in great stereo sound. -
Remote Control - Leave Your Smartphone In Your Bag
Mount the Jabra Streamer on the car's dashboard and leave your smartphone in your bag or pocket. Use the control panel to pause, play and skip tracks, switch between music and calls and activate and engage Siri or Google Now remotely on your smartphone. -
Intuitive Plug & Play Solution
Jabra Streamer is a true plug & play solution. When connected to your car stereo and paired to your smartphone, you're ready to stream music. And it automatically switches on and off with your car ignition, so you don't have to think about it. -
Recommended App for Jabra Streamer
Forgot where you parked your car? Find the last location where Jabra Streamer was disconnected with the "Find My Car" feature in the Jabra Assist app.
- Jabra Streamer - Bluetooth wireless audio transmitter for mobile phone
- Product Type
- Intended For
- Mobile phone
- Suitable For Installation
- Car
- Integrated Components
- Microphone
- Wireless Interface
- Bluetooth
- Package Content
- Car power adapter, mounting plate, Bluetooth audio transmitter, audio extension cable
- 6 cm x 0.93 cm x 1.91 cm
- 38 g
- Product Type
- Intended For
- Mobile phone
- Car
- Microphone
- Bluetooth 3.0
- Max Operating Distance
- 10 m
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Package Content
- 6 cm
- 0.93 cm
- 1.91 cm
- 38 g
- Connections
- USB - 4 pin USB Type A (power only) , Audio output - mini-phone stereo 3.5 mm
- Control buttons, charging via USB connector, voice control, hands-free calls capability
- Placing / Mounting
- Dashboard
