Jabra Storm
Jabra Storm
Quicklinx: 9ZD1WS00 Mfr#: 100-93070000-60
Whether you're on the move or ankle deep in dirt and grit, you get crystal clear conversations with Jabra Storm. Enjoy the Bluetooth headset based on breakthrough microPOWER battery technology - the Jabra Storm is significantly smaller, delivers longer talk time and offers a better comfort experience.
  • Reduces wind noise
    Wind Noise Blackout reduces wind noise, shielding your conversations even in windy conditions. Take your calls outdoors and don't worry about the wind.
  • All-day comfort
    Storm is designed for all-day wear. It has a slim, extra comfortable design with a perfectly balanced weight. Storm fits discreetly behind your ear, so you'll hardly notice you're wearing it.
  • HD sound with noise reduction
    Advanced Noise Blackout technology ensures clear, noise-free calls. Dual microphones reduce background noise, making you easy to hear. HD Voice* brings high-definition sound quality to both ends of the call. Is it windy outside? No problem: just put on the special wind sock to completely silence all wind noise. Remove it again easily once you no longer need the extra wind protection.
  • More power
    You don’t have to worry about running out of battery. Storm delivers up to 9 hours of talk time.
  • Simple pairing with NFC
    Do you have an NFC-enabled phone? Pair it with your Storm by simply tapping the two together. Quick and effortless.
  • Voice control
    Use your voice to control the headset. Answer or reject calls by speaking to Storm.
  • ALL-DAY COMFORT
  • HD SOUND WITH NOISE REDUCTION
  • MORE POWER
  • REDUCES WIND NOISE
  • SIMPLE PAIRING WITH NFC
  • VOICE CONTROL
Jabra Storm - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Mono
Impedance
32 Ohm
Active Noise Canceling
Microphone
Built-in
Controls
Volume, on/off, answer/end
1-year warranty
6.2 cm
1.6 cm
8.4 cm
7.9 g
Recommended Use
Max Operating Distance
30 m
Headphones
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Active Noise Cancelling Technology
Wind Noise Blackout
Impedance
32 Ohm
Microphone
Frequency Response
300 - 3400 Hz
Audio Input Details
Omni-directional
Remote Control
Controls
Wireless Link
Transmission Range
30 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
Wind protection cap, gel ear tip
Cable Details
USB charge cable
GOST, IC, FCC, RoHS, REACH
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Standby Time
240 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
